The payload formatter for this device worked fine in the Helium console but when used as the codec in Chirpstack the results comes back as an error. I haven’t found a Chirpstack v4 specific codec online and tech support has not responded to my inquiry.
function Decoder(bytes, port) {
var decoded = {};
for (var i = 0; i < bytes.length; ) {
var channel_id = bytes[i++];
var channel_type = bytes[i++];
// BATTERY
if (channel_id === 0x01 && channel_type === 0x75) {
decoded.battery = bytes[i];
i += 1;
// WATER LEVEL
else if (channel_id === 0x03 && channel_type === 0x77) {
decoded.water_level = readInt16LE(bytes.slice(i, i + 2));
i += 2;
} else {
break;
return decoded;
* bytes to number
function readUInt16LE(bytes) {
var value = (bytes[1] << 8) + bytes[0];
return value & 0xffff;
function readInt16LE(bytes) {
var ref = readUInt16LE(bytes);
return ref > 0x7fff ? ref - 0x10000 : ref;
