I’m currently trying to set up a SIM7000E cellular modem with a Raspberry Pi Zero W running ChirpStack 4.7.0 base. I am aiming to establish a PPP connection over the SIM7000E by waveshare. However, I’ve encountered some issues and could use your assistance.
Hardware Setup:
- Raspberry Pi Zero W with ChirpStack installed.
- SIM7000E HAT connected via UART (specifically, /dev/ttyAMA0).
- PPP connection established using
pppdand the necessarychatscript for the SIM7000E.
Packages Installed:
pppcomgtminicomchat
Problem:
I can communicate with the SIM7000E using minicom and send AT commands successfully (e.g., AT, AT+CSQ, etc.), but when trying to initiate a PPP connection with:
sudo pppd call sim7000
The process hangs, and I do not get a working PPP interface (ppp0). I can also see the serial port (/dev/ttyAMA0) being used but am unable to see much activity when I run:
cat /dev/ttyAMA0
Things I’ve Tried:
- Verified the SIM7000E is correctly initialized with minicom using basic AT commands (e.g.,
AT,AT+CSQ). - Tested the chat script for sending commands like
ATZ, but the script hangs atATand doesn’t move forward.
Additional Info:
As I have already configured this setup on Raspberry Pi OS, I suspect the issue lies within the software environment on ChirpStack which appears to be more stripped down. Specifically, in the /etc/ppp directory, I see fewer files and folders, which makes me wonder if this could be a contributing factor to the problem.
Questions:
- Does anyone have a working chat script for SIM7000E on Raspberry Pi Zero W that I can compare against my current setup?
- Are there any specific PPP options or serial port configurations I may have missed for stable connectivity?
- Is there any advice or debugging steps that could help identify what’s causing the “Connect script failed” issue?
Thank you in advance for any guidance or suggestions you can provide!
