Hello all,
I am currently trying to connect a Heltec ESP OLED V2 to the Chirpstack. I use a Dragino LPS8N 868Mhz for this.
Chirpstack I have installed in a LTX container, Chirpstack recognizes the Dragino without problems.
Now I am currently trying to connect my Heltec ESP to it, for this I chose a predefined example to send.
#include "heltec.h"
#define BAND 868E6 //you can set band here directly,e.g. 868E6,915E6
int counter = 0;
void setup() {
//WIFI Kit series V1 not support Vext control
Heltec.begin(true /*DisplayEnable Enable*/, true /*Heltec.LoRa Disable*/, true /*Serial Enable*/, true /*PABOOST Enable*/, BAND /*long BAND*/);
void loop() {
Serial.print("Sending packet: ");
Serial.println(counter);
// send packet
Heltec.LoRa.beginPacket();
Heltec.LoRa.print("hello ");
Heltec.LoRa.print(counter);
Heltec.LoRa.endPacket();
counter++;
digitalWrite(25, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(25, LOW); // turn the LED off by making the voltage LOW
Unfortunately, however, I don’t see any messages when I go into the Live LORAWAN FRAMES.
Shouldn’t all sensors appear here now that are in the same frequency band, or did I misunderstand something here?
Thanks for the support
I am still a beginner in the field of Lora.
Kind regards
