I’ve installed my chirpstack time ago and it was moreless working properly, for perfomance reasons I had to reset my server and once it turned on my chirpstack didn’t work anymore.
So in summary I deleted everything including docker, the docker images and my chirpstack installation as well. Then I tried to reinstall everything but I’m getting the next message once I run the docker:
ERROR: for chirpstack-application-server Cannot start service chirpstack-application-server: driver failed programming external connectivity on endpoint chirpstack-docker_chirpstack-application-server_1 (xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx): Error starting userland proxy: listen tcp4 0.0.0.0:8080: bind: address already in use
In my settings before I started the docket I specified to my chirpstack-application-server to use 9090:9090 port, also I’ve reinstalled several times all and I still getting this same message.
By the way I’m doing all this in CentOS.
What might I haven’t notice?
UPDATE
I just could fix this problem, the solution was that I had to edit both .yml files for the docker compose, in this case I had to change the port in both files:
sudo vim ~/chirpstack-docker/docker-compose-env.yml
sudo vim ~/chirpstack-docker/docker-compose.yml
But now I can’t acccess to the platform via web browser
Regards
