Hey Orne, we are using the most updated gw-bridge in our blockchain LPWAN server, now we have like 6000 gateways online and the bridge is down quite often.
We suspect There might be some sort of race condition / deadlock in the code that is easily exposed when the load is high.
does it have something to do with instances? it is running NS+AS+gw-bridge+Blockchain service containder with Kubernetes
you can try our app in apple/google play called MXC datadash, we have 6k GWs online with two SX1302 (essentially two packet forwarder each gw, so 12k connections)
We aren’t able to reproduce the gateway-bridge problem on our test-server, running lorhammer with 30000 gateways and two real gateways are regularly updated and gateway-bridge is fine.
But in our blockchain supernode 6000 gateway crashed it . same environment.
