hello everyone ,
after configuring the Pico Gateway from the JAva gateway tool and adding the gateway parameters in the chirpstack application server and so on . the status of my gateway never change ! it is always " Never " … what should i do please ?
it will be “Never” status until it receive and send frame from any chirpstack-registered endnode through it. also check the gw packetforwarder configuration for correct address and port
yup , solved that when i set my ip address in the config file of the bridge gateway and in the gateway’s java tool through port 1700 .
