I want create an api key for a tenant in chirpstack api grpc
i’m trying to create with python, at first i genarete in the interface, but after i want to generate a new one for every tenant, how can i do this with python, not in a interface
The only way I know to generate API keys besides the UI is to use the CLI:
~ $ chirpstack --help
ChirpStack is an open-source LoRaWAN(TM) Network Server
Usage: chirpstack --config <DIR> [COMMAND]
Commands:
configfile
Print the configuration template
print-ds
Print the device-session for debugging
import-lorawan-device-profiles
Import lorawan-device-profiles repository
import-legacy-lorawan-devices-repository
Import legacy lorawan-devices repository
create-api-key
Create global API key
migrate-device-sessions-to-postgres
Migrate device-sessions from Redis to PostgreSQL
help
Print this message or the help of the given subcommand(s)
Options:
-c, --config <DIR> Path to configuration directory
-h, --help Print help
-V, --version Print version
I believe you can create a global API key, which will then allow you to manage tenants with gRPC?
yes, i can, but i want create a tenant using global api key, and after creating an api key for a tenant using the global api key, but i descovery isant possible to do this, i realy nead creating by interface
i dont have access to this, i only have access to gRPC python chirpstack api
So you want to programmatically create the API key? Actually, I did that with the HTTP API that the UI uses.
Since the UI is always there and the default password is admin/admin, I wrote code that creates the global API key as if I did it in person. Once the API key is generated, all further actions can be taken with gRPC.
If I understand you correctly You want separate API Keys for different tenants and later allow your tenants to use chirpstack API using their own keys.
I may be wrong but I think you can only get multiple global API keys that allow you to modify all your tenants and cannot be limited to a single one.
In that case I would consider a PR to chirpstack to make the world better or create your own API Proxy (http, grpc whatever you want) that would use your own keys and permission validation logic.
