How can I decode LoRaWAN frames in ChirpStack Gateways?
Dear all,
I am encountering some issues with LoRaWAN frames in ChirpStack Gateways. According to the result, I need to understand the pay_payload , rx_info , and tx_info construction. Additionally, if these are transmitted in a MQTT topic and the feedback is in hexadecimal format, how can I decode it?
Case in point, I try to use lora-packet of library to assist me with the decoding process. This result is not ideal. Does anyone have similar experience or other methods?
I really appreciate you.
Source:
lora-packet: lora-packet
Gateway payload formats are available in the protobuf definitions, with some additional descriptions here:
https://www.chirpstack.io/docs/chirpstack-gateway-bridge/payloads/events.html
For decrypted device payloads, you will want to use an integration and have ChirpStack decrypt them for you before forwarding them on:
https://www.chirpstack.io/docs/chirpstack/integrations/events.html
If you’re asking how to decrypt the device payloads yourself, this probably isn’t the best place to ask, as most people here are using ChirpStack to do that work.
Ok! I see. Thank you, sir!
