Tried multiple settings, keep getting ‘context deadline exceeded’.
All my LoRaServer services are instantiated on the same platform (via docker).
try the following setting:
loraserver:8000
Best regards,
DeHi
loraserver:8000 … context deadline exceeded.
I should add that I am not using the docker-compose approach, but a single container within which is running the ENTIRE set of loraserver components.
Setting Network-server server* to 0.0.0.0:8000 seems to work … I am not sure why. Might be related to the docker port settings.
In case the instance is on the same host with default settings, it should be localhost:8000
(as in the help text under the field )
localhost:8000 … context deadline exceeded.
A few points here…
It would be helpful if the documentation provided specific clarity re: what exactly is exposed at this host:port. I’m guessing it is the host:port of the NS gRPC API interface? The UI doc is pretty thin on detail … https://www.loraserver.io/lora-app-server/use/network-servers/
in this specific case, the NS and AS are running within the same container, with the AS web UI running on a different host. No issues accessing the AS via the web interface (its port is exposed by the container). Network-server server* set to localhost:8000, loraserver:8000, : 8000 … none of these work. Only 0.0.0.0:8000 does.
“context deadline exceeded” provides me no useful info other than “something is not right?”.
Cheers
