I’m using the latest version of ChirpStack, and I’m trying to execute the command make docker-devshell-ui
. However, I encounter the following error:
Commande : “make docker-devshell-ui”
Response "
docker compose run --rm --service-ports --name chirpstack-ui chirpstack-ui bash
no such service: chirpstack-ui
make: *** [Makefile:57: docker-devshell-ui] Error 1"
I want to run the development Docker environment for the UI. I can create the chirpstack-ui
container, but I’m not sure where to put the relevant configuration information. I assume it should go into the Dockerfile-devel
, but I don’t know how to proceed.
Can someone help to execute this command to enter in the developpement ui container ?
Best regards,
José
