Tell me if chirpstack can work with large numbers of devices. For example 5000+ devices?
It always depends on how often a device sends data - but 5000 should not be a problem. myself, i have about 12’000 devices, send data every 10 minutes. no problem at all.
cheers
Can you share your resource experience? how much database to take? how much disk space to free, if we consider your case
About Ressources its hard to say, as i do not manage all the things by myself.
Chirpstack Server (Running Chirpstack-Application-Server and Chirpstack Network Server)
- RAM: 4 GB
- Disk Space 25 GB
- CPU 4 vCPUs from our ESX Farm (Intel(R) Xeon(R) Gold 6248 CPU @ 2.50GHz)
I would say redis and mqtt is about the same. but the systems are not busy at all…
about the postgress database - at the moment the database is about 750MB - so also not big.
i don’t know if this really helps you, but yeah.
Hi, one question, how many gateways you have for manage the 12000 devices??
It does not make sense to answer this question - as the devices are on different locations. so we have more then 150 locations, so more then 150 gateways
so you can see, i have a lot of gateways because the distance between this locations ist to big and can’t be covered.
if you have less locations, you need less gateways i think. but there i am not really a expert, on how many devices on a gateway. for sure, its also important how often your devices send data and the size of the payload. this could in a bad case result in conflicts in the air (collisions in the frequence band)
here is a discussion / calculation about this topic
Ok, thanks for you response
hi, yes we have implemented this with HA and have good experiences with it
Have you seen this Topic? Describes a lot of it:
If you have specific questions then i am happy to help. sharing experiences is a big question
and HA does not really fit in this topic (nr. of conneced devices)
I’m wondering how to connect a large number of devices. Does each device need to have its own gateway and its own application? How can I properly distribute
Please share your experience. I’m interested in how to correctly distribute devices among different applications and whether how many devices on one application affect the quality of communication or not
It depends on the device that they accept large amount of data.
it’s not limited by chirpstack software.
@brocaar do you have any specific numbers from production use of Chirpstack?
Im aware that maximum number of handled devices has many variables but still considering one average machine for it without special scaling… Would you say its around 10k, 100k or 1mil devices?
A quick update in the topic …
A few weeks ago we did some Chirpstack performance testing on a i7 laptop using chirpstack simulator.
In general I would say that the problem is not actually in “how many devices can be connected” but how many activations and up-link data per second the system can handle.
We tested different scenarios, observed CPU, RAM & behavior.
Chirpstack was still working fine while activating 100 devices/s processing 330 uplinks/s (using 5k simulated devices, 10k worked pretty the same with double uplink interval & double activation time).
Chripstack + postgres + redis during that time used ~6 CPU cores and 500MB RAM.
While trying to go above these values we got some unresponsiveness, unfinished activations etc.
In general 330 uplinks / sec is quite nice considering that devices normally send data every 1 hour.
Using simple math and assuming equal data distribution that should give us something ~1 Million devices. But… probably we would encounter different issues during that time (like slow postgres queries) and most probably real production installations will not be distributed equally in time with activations and uplinks.
In my judgement you should expect production chirpstack to handle ~100k devices (1 uplink/hour) on an 8 core machine with reasonable RAM (lets say 16GB). When redis/postgres are deployed separately - 4 cores should be enough.
In such a setup you must monitor CPU and RAM during activation and uplink peaks and see how the system performs.
