Hello all, is there any way to implement this button on python script??
https://www.chirpstack.io/docs/chirpstack/api/api.html
Search for all instances of “flush”. The method is under DeviceService
For anyone that may need it
# Connect without using TLS.
channel = grpc.insecure_channel(server, options=(('grpc.enable_http_proxy', 0), ))
# Device-queue API client.
client = api.DeviceServiceStub(channel)
# Define the API key meta-data.
auth_token = [("authorization", "Bearer %s" % api_token)]
# Construct request.
req = api.FlushDevNoncesRequest()
req.dev_eui = dev_eui
_ = client.FlushDevNonces(req, metadata=auth_token)
