How to change the time in lorawan frames
1999-11-29 19:14:42
DevAddr: 004cc81b
DevEUI: 58c645ce0ad8f5b3
1999-11-29 19:13:39
DevAddr: 004cc81b
how to fix these dates as it showing to me on lorawan frames on chirpstack
It’s probably that the time of the server Chirpstack is running on is incorrect. Chirpstack should sync time with whatever machine it is running on.
  • gwTime:“1999-11-30T00:14:42.056139+00:00” it showing from gw as I am using wm 1302 seed lorawan gateway module
Then this is not a Chirpstack problem but a seeed problem, you could try their forums: https://forum.seeedstudio.com/. Or check the NTP settings on the device.
I assume you are using the Seeed module with a Pi. Are you using the ChirpStack Gateway OS? It should automatically time-sync. If you are using an other distro, make sure to setup NTP synchronization.
