Hi, I’m new here and I’m having the following problem:
1- I configured my brownan pico next gateway to operate on an AU915 basic station.
2- the gateway appears as online in the ChirpStack panel. However, it is appearing with the Region ID and Region common-name configured as EU868, when the correct one should be AU915.
Please, could someone help me with how I can solve it?
Hi! I encountered the same issue while using ChirpStack. In my case, I was running the network server through Docker. The configuration files in docker-compose.yml contain settings for regional configurations. I simply changed the region from EU868 to AU915 in these configuration lines, and it loaded the correct configuration file.
