@sagarpatel sure.
Yes the ports are open on the firewall:
— gateway-bridge
firewall-cmd --list-all
ports: 7001/udp 4241/tcp 1700/tcp 1700/udp
– network-server
ports: 7001/udp 4241/tcp 8000/tcp 8000/udp 1700/tcp 1700/udp
And here the log of the gateway:
|udp-packet-forwarder|INFO: [down] PULL_ACK received in 1 ms|
|udp-packet-forwarder|INFO: Received pkt from mote: 01F86988 (fcnt=949)|
|udp-packet-forwarder|JSON up: {"rxpk":[{"tmst":85082236,"chan":1,"rfch":1,"freq":868.300000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-14.5,"rssi":-111,"size":54,"data":"QIhp+AGAtQMDCqtSVGmL85gxZMDCESAxV7E6qIGCpnevMGDsIxAwUNfe9PiUO4nsWIIltJTu"}]}|
|gateway-bridge|time="2020-11-03T09:35:22+01:00" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/fc...32/event/up uplink_id=bebeade1-29e6-4436-916d-fc7a0cf3fb57|
|udp-packet-forwarder|INFO: [up] PUSH_ACK received in 0 ms|
|udp-packet-forwarder|INFO: Disabling GPS mode for concentrator's counter...|
|udp-packet-forwarder|INFO: host/sx1301 time offset=(1604392437s:111425µs) - drift=-22µs|
|udp-packet-forwarder|INFO: Enabling GPS mode for concentrator's counter.|
|udp-packet-forwarder|INFO: host/sx1301 time offset=(1604392437s:111471µs) - drift=46µs|
|udp-packet-forwarder|INFO: Received pkt from mote: 5061726B (fcnt=18501)|
|udp-packet-forwarder|JSON up: {"rxpk":[{"tmst":204173692,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-17.0,"rssi":-113,"size":23,"data":"AGtyYVBfRUhDbmVnQV/UAgDCkBUdWRU="}]}|
|gateway-bridge|time="2020-11-03T09:37:21+01:00" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/fc...32/event/up uplink_id=b0bcfabe-bd61-4206-9f8b-ded4fe8ff58a|
|udp-packet-forwarder|INFO: host/sx1301 time offset=(1604392437s:111470µs) - drift=-1µs|
|udp-packet-forwarder|INFO: Received pkt from mote: 014B06B5 (fcnt=654)|
|udp-packet-forwarder|JSON up: {"rxpk":[{"tmst":258921956,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-14.2,"rssi":-112,"size":54,"data":"QLUGSwGAjgIDMtvg/Wu68mrFnOkNTF9xwVf7VcnkgcvsHsH0WDRoYLlMav4NrFnmIz21XYwa"}]}|
|gateway-bridge|time="2020-11-03T09:38:16+01:00" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/fc...32/event/up uplink_id=f4556463-c196-4e05-859e-668549839074|
|udp-packet-forwarder|INFO: [up] PUSH_ACK received in 4 ms|
|udp-packet-forwarder|##### 2020-11-03 08:38:59 GMT #####|
|udp-packet-forwarder|### [UPSTREAM] ###|
|udp-packet-forwarder|# RF packets received by concentrator: 14|
|udp-packet-forwarder|# CRC_OK: 42.86%, CRC_FAIL: 57.14%, NO_CRC: 0.00%|
|udp-packet-forwarder|# RF packets forwarded: 6 (262 bytes)|
|udp-packet-forwarder|# PUSH_DATA datagrams sent: 6 (1410 bytes)|
|udp-packet-forwarder|# PUSH_DATA acknowledged: 100.00%|
|udp-packet-forwarder|### [DOWNSTREAM] ###|
|udp-packet-forwarder|# PULL_DATA sent: 30 (100.00% acknowledged)|
|udp-packet-forwarder|# PULL_RESP(onse) datagrams received: 0 (0 bytes)|
|udp-packet-forwarder|# RF packets sent to concentrator: 0 (0 bytes)|
|udp-packet-forwarder|# TX errors: 0|
|udp-packet-forwarder|# BEACON queued: 0|
|udp-packet-forwarder|# BEACON sent so far: 0|
|udp-packet-forwarder|# BEACON rejected: 0|
|udp-packet-forwarder|### [JIT] ###|
|udp-packet-forwarder|# SX1301 time (PPS): 242536515|
|udp-packet-forwarder|src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty|
|udp-packet-forwarder|### [GPS] ###|
|udp-packet-forwarder|# GPS sync is disabled|
|udp-packet-forwarder|##### END #####|
|udp-packet-forwarder|JSON up: {"stat":{"time":"2020-11-03 08:38:59 GMT","rxnb":14,"rxok":6,"rxfw":6,"ackr":100.0,"dwnb":0,"txnb":0}}|
|udp-packet-forwarder|INFO: [up] PUSH_ACK received in 15 ms|
|udp-packet-forwarder|INFO: host/sx1301 time offset=(1604392437s:111447µs) - drift=-23µs|
|gateway-bridge|time="2020-11-03T09:38:59+01:00" level=info msg="integration/mqtt: publishing event" event=stats qos=0 stats_id=36cfb34f-e635-4c52-84ec-7184f3d11c52 topic=gateway/fc...32/event/stats|
|udp-packet-forwarder|INFO: Received pkt from mote: 01E47431 (fcnt=257)|
|udp-packet-forwarder|JSON up: {"rxpk":[{"tmst":314296252,"chan":0,"rfch":1,"freq":868.100000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-20.2,"rssi":-113,"size":54,"data":"QDF05AGAAQEDJs9jrgwVb2pWCpaFaZaaZkz19toLt+Zk0iwu+WVihlnwup0DTNYfcx2STnuO"}]}|
|gateway-bridge|time="2020-11-03T09:39:11+01:00" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/fc...32/event/up uplink_id=09232cd0-2f1a-469a-bf28-854afe34fd60|
|udp-packet-forwarder|INFO: Received pkt from mote: 0183A255 (fcnt=142)|
|udp-packet-forwarder|JSON up: {"rxpk":[{"tmst":350062652,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-13.0,"rssi":-111,"size":54,"data":"QFWigwGAjgADN5DAHQQFJVJ2PQjo/FfMIyyQfgtm1PwxLkD9srKOIMO+QC6jjDw5UEgrO1hR"}]}|
|gateway-bridge|time="2020-11-03T09:39:47+01:00" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/fc...32/event/up uplink_id=d3b4c924-12b7-42b7-a929-3614f50afa4b|
|udp-packet-forwarder|INFO: host/sx1301 time offset=(1604392437s:111506µs) - drift=59µs|
|udp-packet-forwarder|INFO: Received pkt from mote: 011FBDA0 (fcnt=943)|
|udp-packet-forwarder|JSON up: {"rxpk":[{"tmst":380700652,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-15.5,"rssi":-113,"size":54,"data":"QKC9HwGArwMDGimBsNDMwYwnsaDBR6+3AWx9gukiFR5YbnWpUyaLshleMfKJ4IC9dCzXhgG4"}]}|
|gateway-bridge|time="2020-11-03T09:40:17+01:00" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/fc...32/event/up uplink_id=21d3045a-9072-424a-99f4-e83037e23c3a|
|udp-packet-forwarder|INFO: Received pkt from mote: 00658612 (fcnt=956)|
|udp-packet-forwarder|JSON up: {"rxpk":[{"tmst":386558228,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-8.8,"rssi":-112,"size":54,"data":"QBKGZQCAvAMDjUcMA29YrDJGdOm+xIlodrNL5/7CK1c18iI4wweZ8HFx7Doq4M5JQuZY2/Lh"}]}|
|gateway-bridge|time="2020-11-03T09:40:23+01:00" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/fc...32/event/up uplink_id=7feaac52-f656-4c10-b815-ee79bb2e7682|
|udp-packet-forwarder|INFO: host/sx1301 time offset=(1604392437s:111500µs) - drift=-6µs|
|udp-packet-forwarder|INFO: Received pkt from mote: 01F86988 (fcnt=950)|
|udp-packet-forwarder|JSON up: {"rxpk":[{"tmst":446857116,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-15.0,"rssi":-112,"size":54,"data":"QIhp+AGAtgMDyxE8VVmjCdGZTej8FD6mnimZU1GkSVhQQ+7t4Pww9bTrQpqyr+jduLZHe8yu"}]}|
|gateway-bridge|time="2020-11-03T09:41:24+01:00" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/fc...32/event/up uplink_id=b3a4ff5d-b64c-4a84-8634-9b2520ce157a|
|udp-packet-forwarder|JSON up: {"rxpk":[{"tmst":459684060,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-16.0,"rssi":-112,"size":23,"data":"AGtyYVBfRUhDbmVnQV/UAgDDkM0K3UY="}]}|
|gateway-bridge|time="2020-11-03T09:41:36+01:00" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/fc...f32/event/up uplink_id=c867ed29-4c67-4bfc-8f8e-be8463c145ee|
|udp-packet-forwarder|INFO: host/sx1301 time offset=(1604392437s:111498µs) - drift=-2µs|
If needed I can share the whole log (with kernel info and so on).
EDIT: What is weird is that if I follow the LoRa frames of this gateway in chirpstack WebUI I can see data but the devices is still shown as offline:
Here some output from systemctl status loraserver.service -l (on the network server):
Nov 03 11:16:10 network-server chirpstack-network-server[3476]: time="2020-11-03T11:16:10+01:00" level=info msg="gateway/amqp: uplink event received" gateway_id=fc...fb uplink_id=cbc0c386-0cb1-4a04-9607-72dca703cdaf
Nov 03 11:16:10 network-server chirpstack-network-server[3476]: time="2020-11-03T11:16:10+01:00" level=error msg="uplink: processing uplink frame error" ctx_id=fb81d433-d6c0-4de9-bedf-b2517e0ae131 error="unmarshal phypayload error: lorawan: 18 bytes of data are expected"
Nov 03 11:16:12 network-server chirpstack-network-server[3476]: time="2020-11-03T11:16:12+01:00" level=info msg="gateway/amqp: uplink event received" gateway_id=fc...fb uplink_id=052f4e45-244b-4016-95e5-8748b6e514fd
Nov 03 11:16:12 network-server chirpstack-network-server[3476]: time="2020-11-03T11:16:12+01:00" level=info msg="gateway/amqp: uplink event received" gateway_id=fc...32 uplink_id=759beece-2413-4450-ad9a-d59eca1dcaad
Nov 03 11:16:12 network-server chirpstack-network-server[3476]: time="2020-11-03T11:16:12+01:00" level=error msg="uplink: processing uplink frame error" ctx_id=1d35f954-79a9-4a06-a296-0e7738fbbe12 error="zero items in collect set"
So it looks like that the network-server recieve the data:
But for some reason I get the following error:
And here some output of the application-server:
Nov 03 17:09:28 application-server chirpstack-application-server[27605]: time="2020-11-03T17:09:28+01:00" level=info msg="finished unary call with code OK" ctx_id=4f3f3ece-44f6-4cae-bd26-88ce7d76e86c grpc.code=OK grpc.method=Get grpc.service=api.OrganizationService grpc.start_time="2020-11-03T17:09:28+01:00" grpc.time_ms=1.981 peer.address="127.0.0.1:54886" span.kind=server system=grpc
Nov 03 17:09:28 application-server chirpstack-application-server[27605]: time="2020-11-03T17:09:28+01:00" level=info msg="finished unary call with code OK" ctx_id=1159aa8b-403e-486d-93d4-d551bfb14242 grpc.code=OK grpc.method=List grpc.service=api.OrganizationService grpc.start_time="2020-11-03T17:09:28+01:00" grpc.time_ms=3.829 peer.address="127.0.0.1:54886" span.kind=server system=grpc
Nov 03 17:09:29 application-server chirpstack-application-server[27605]: time="2020-11-03T17:09:29+01:00" level=info msg="finished client unary call" ctx_id=19505601-206b-40e7-9fe2-3b1cfaa6afa6 grpc.code=OK grpc.ctx_id=4c007f38-4f05-4084-a163-5f869af453b1 grpc.duration=3.00695ms grpc.method=GetGateway grpc.service=ns.NetworkServerService span.kind=client system=grpc
Nov 03 17:09:29 application-server chirpstack-application-server[27605]: time="2020-11-03T17:09:29+01:00" level=info msg="finished unary call with code OK" ctx_id=19505601-206b-40e7-9fe2-3b1cfaa6afa6 grpc.code=OK grpc.method=Get grpc.service=api.GatewayService grpc.start_time="2020-11-03T17:09:29+01:00" grpc.time_ms=7.896 peer.address="127.0.0.1:54892" span.kind=server system=grpc
Nov 03 17:09:29 application-server chirpstack-application-server[27605]: time="2020-11-03T17:09:29+01:00" level=info msg="finished unary call with code OK" ctx_id=d640158b-6f69-4e27-a408-7789a0c3b40c grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time="2020-11-03T17:09:29+01:00" grpc.time_ms=3.393 peer.address="127.0.0.1:54892" span.kind=server system=grpc
On a first guess I was thinking that something was wrong with the message send by the device. Therefore, I installed a test instance of chirpstack (everything in one docker) and registered the device on this test instance. On the docker chirpstack installation the device could join and send messages without any issue. Therefore, it is save to say that the issue is not related to the device (I checked devEUI and AppKey (on the AppKey also ensure that I put it correctly MSB, LSB)) but something is wrong on my configuration.
