How to connect gateway-os-base to Gateway Bridge on different server
I seem to have more luck using the RAK software on my pi with the semtech udp for the 2245 rather then the chirpstack OS mqtt using concentratord. Not sure why, i might try latest version again and make sure I didn’t miss configure something.
A little hack you could try, use rak software and setup the gateway with sudo gateway-config and fill in for details for your GW, then chose TTN -> once done go edit the global.json to point the UDP to your chirpstack ns UDP rather then the TTN router/port update with your ipaddress/domain and port by editing and saving that file. Restart pi and you should be good.
Using the RAK software…
/opt/ttn-gateway/packet_forwarder/lora_pkt_fwd/global_conf.json
head down to bottom of file, in the last block…
"gateway_conf": {
                "gateway_ID": "0000000000000000",
                /* change with default server address/ports, or overwrite in local_conf.json */
                "server_address": "< YOUR IP/DOMAIN HERE >",
                "serv_port_up": <UDP PORT>,
                "serv_port_down": <UDP PORT>,
                /* adjust the following parameters for your network */
                "keepalive_interval": 10,
                "stat_interval": 30,
                "push_timeout_ms": 100,
                /* forward only valid packets */
                "forward_crc_valid": true,
                "forward_crc_error": false,
                "forward_crc_disabled": false,
                /* gps enable */
                "gps_tty_path": "/dev/ttyAMA0",
                "fake_gps": false,
                "ref_latitude": 10,
                "ref_longitude": 20,
                "ref_altitude": -1,
                "autoquit_threshold": 20
