General question… How can I edit the .toml (configuration files?) for the network server and the application server? I don’t know what editor works nor the syntax…
Thanks Rob
Thanks Rob
Just find your configuration file and run command of edit or use desktop,
Command is like:
vim xxx.toml
I would also go with vi for quick configuration edits, but I believe nano is considered friendly for new users to *NIX environments.
you need to go to your docker folder, like this:
cd chirpstack-docker/
then enter the configuration folder like this:
cd configuration/
now look for your files like this:
dir
then enter the one you want to edit, like this (example):
nano chirpstack-gateway-bridge.toml
and once you enter the file, you can edit, remove, or add whatever you want to the file whilst you are on the cmd. (Press Ctrl+S to save, Ctrl+X to exit, etc)…
Hope I helped you!
Nicolas,
That is exactly what I needed. I have not tried it yet but hope to do that today. I have to setup the configuration files for Network and the Application Server for frequency settings etc (USA).
Thanks Much
Rob
PD: Those commands are used in LINUX based chirpstack servers.
Your welcome!
I just noticed that I only responded to Nicolas… Sorry …thank to all for your prompt replies.
Rob
Hi Nicolas,
When I try to cd into my /etc/chirpstack-application-server/ …I get access denied? I believe my sign in is an admin account. I am using Ubuntu 20.04 LTS
Thanks Rob
I like MS Word, that way I can use my favorite fonts and highlight any important settings.
Nicolas, I just looked at the message again it says : Permission denied
I don’t think you’re ready to work on Chirpstack. You gotta start with the basics first, like how to edit a file in linux.
We are here to help our mates, not to highlight their weaknesses.
Yo do not have to enter the folder you mentioned. But a general docker folder instead.
Open your terminal and write “dir”. Then you will see the possible folders in which you can move on.
Guidance:
After this, you only need to enter the file using:
“nano chirpstack-application-server.toml”
In case “permission denied” stands out. Try adding “sudo” at the beggining of instruction. Like this:
sudo nano chirpstack-application-server.toml
Hi Nicolas
Success!!! I got those two files edited today… Cudos to you man!
Thanks Rob
