Hi all.
I successfully installed Chirpstack Full Os 3.6.0 on a Raspberry PI 3.
I’m reading all the documentation but I don’t happen to find the web interface.
Where shall I “enable” the web interface of chirpstack?
I’ve also checked this post, but with no luck.
Thanks in advance.
By default ChirpStack runs on port 8080, thus it would be http://IP-OF-RASPBERRY-PI:8080.
If you’re installing from scratch, make sure you also install chirpstack (for instance, on the Rpi or Ubuntu) you need to run “sudo apt install chirpstack”. That’s what I’ve discovered when I looked for open/listening ports and couldn’t find anything listing on 8080.
I hope this helps…
