How To Host Chirpstack on a subdomain such as "example.com/console" using Ansible
Hello, I have successfully setup chirpstack on my domain. However, I want to host my home page on my domain and host chirpstack on a subdomain like “example.com/console” inorder to prevent access to the application ui from my end users.
My end goal is to link all the features I want from chirpstack application server to my own private web applications.
I have tried changing adding the subdomain “example.com/console” in the group_vars/single_server.yml file, however letsencrypt doesn’t seem to generate certificates for this domains.
this is not subdomain, this is path. subdomain must be look like this http://console.example.com
Sorry my bad. I already have the subdomain “example.com” and chirpstack works fine whenever I access from that subdomain. However I want to move chirpstack to a path as I want to host my products home page on our subdomain “example.com
bind the app server to another port instead of 8080 and use nginx f.e.
Thanks, nginx f.e.?
Also do you mind throwing light on where I can find the configuration files to make amendments like I said I used ansible to setup my remote instance from my local pc
I mean “for example”
here, of course: https://nginx.org/en/
Oo great. I understand there is an nginx server gets setup while using the ansible playbook (https://github.com/brocaar/chirpstack-ansible-playbook/blob/master/roles/chirpstack-application-server/templates/chirpstack-application-server.nginx).
I want to confirm if this is the right file to edit, for the question which I put up initially, before I start making changes to it.
