I have a Raspberry Pi 4B+, RAK2245 Ver B that is mounted on RAKWisLink LoRa RAK2243 Ver. A hat.
I intend to install the chirpstack-concentratord-sx1301 along the official Raspberry Pi OS (64 bit).
I modified the config.txt to allow hardware communication
dtparam=spi=on
enable_uart=1
dtparam=i2c1=on
dtparam=i2c_arm=on
I downloaded, extracted and ran the binary, however, I got this error.
The error is quite clear? The gateway model is incorrect (you should remove the _eu868), see for an overview of supported models:
https://www.chirpstack.io/docs/chirpstack-concentratord/hardware-support.html
Thank you, funny how I missed that “_eu868”. I was using the precompiled binary provided by Chirpstack
I’ll have to build from source if there is no precompiled library that has been corrected.
I don’t think you need to compile your own, just remove the _eu868 from the model name. It used to be like this in the past, but this has been replaced by region="EU868" configuration, see also:
https://www.chirpstack.io/docs/chirpstack-concentratord/configuration.html
