Hi ,
We are trying to adjust Spreading Factor manually. Is it possible?. How can we manually adjust the Spreading Factor of our node from SF8 to SF12 and wise-versa. Can we adjust through Chirpstack?. Please provide some example on this topic.
Thank You!
Please note that you can implement your own ADR algorithm plugin which could do exactly this
That would at least be the easiest option to implement this.
Thank you for your response. Could you please provide any example for our reference.
Thank You!
Thank you for your response. Is it possible to modify spreading factor in OTAA (Over the Air Activation) for each sensor? @brocaar
