What are the steps needed to run the LoraServer project(https://github.com/brocaar/loraserver) on localhost to make changes on some views in project ???
Thanks.
Thanks.
That’s what I want to ask
To make changes to the UI you’ll need to modify and build lora-app-server on your own; lora-gateway-bridge and loraserver may be installed as you wish.
If you want to debug while developing, you may run lora-app-server after building it and a development React server to see live changes. First, build the Go binary and run it:
make
./build/lora-app-server
On another terminal, navigate to /home/user/go/src/github.com/brocaar/lora-app-server/ui
and run this to start a development server:
npm start
This’ll open localhost:3030
in your browser, which proxies requests to your binary running at localhost:8080
. You may modify the code and watch live changes, and once you are ready you may build the binary with the included UI changes like this:
make clean build
That’ll clear and rebuild static js files to be served by the binary. You may check it’s ok by running it and then opening localhost:8080
(or whatever port you configured) to see your changes.
Remember to create a toml
conf file in one of the valid directories, or give its path through the flag.
