Downloaded docker compose from chirpstack github docker. We are able to test the 1700 port using simulator to act as packet forwarder and send uplink, data to eu868
Now we need to connect Multi Tech in us915 using basic station, Please can you refer us how to set this up?
Hi @Rajan_Raman
Which chirpstack version are you using v3 or v4?
Hi @sagarpatel
Since we are using the basic docker compose provided by chirpstack, does it possible to support and connect multitech basic station or else we need to run Network Server, Application Server as service in an linux machine?
your reponse will help us to move forward!
Basic docker-compose does not provide a basic station in the gateway bridge or does not enable the US915 region.
You need to configure yourself in docker-compose files based on your requirement.
Can you please give me which US sub-band are you using like SUB_BAND_1 or SUB_BAND_2 etc…
If you are in India, please share your contact details so I can connect.
Thanks
Please let not use the forum to organize private calls. This is not very useful for others if they have the same question and find this topic.
