could anyone please explain how to setup the prometheus metric system? So far I’ve added
[metrics.prometheus]
# Enable Prometheus metrics endpoint.
endpoint_enabled=true
# The ip:port to bind the Prometheus metrics server to for serving the
# metrics endpoint.
bind="172.0.0.1:8070"
to the lora-app-server.toml and
scrape_configs:
- job_name: 'loraserver'
# Override the global default and scrape targets from this job every 5 seconds.
scrape_interval: 5s
static_configs:
- targets: ['127.0.0.1:8070']
for Prometheus. Unfortunately no metrics are collected and the target is flagged “down” in Prometheus.
Thank god that was just a stupid typo and not the problem
Also, if both instances are running on the same server then you need to use different ports.
Prometheus and lora-app-server? Isn’t that an open port / connect to port relation? I’m confused now, but I think that is due to the temperature. Do we have a sweating smiley btw?
On topic again: During writing the response and trying a few things I think I just found the problem and it is nearly as simple as the typo. I have two app-server instances which are both 3.x.0, but the one I choose for testing is only 3.1.0…
With this I mean when you both try to export the loraserver and lora-app-server metrics, then they can’t bind to the same port. E.g. use 8070 and 8071 and then configure Prometheus to scrape from both ports
Sorry I am missing something. Do I need to install prometheus or is this already running on the server?
I am suspecting something is already running to produce the graphs on the lora packets in the gateway page of chirpstack.
