Greetings,
I wanted to share with the community my take on implementing the Tektelic Industrial Sensor Node
Important
Make sure when you receive your devices from Tektelic you also receive your keys that are associated with the device from the factory.
You will need to create a device profile for the devices. Here’s what worked for me:
- LoRaWAN Mac Version: 1.0.3
- LoRaWAN Revision: B
- Max EIRP: 30
Decoder:
function Decode(fPort, bytes){
var params = {
"battery_voltage": null,
"output_1": null,
"output_2" : null,
"temperature": null,
"input_1_state": null,
"input_2": null,
"input_3": null,
"input_1_count": null
for(var i = 0; i < bytes.length; i++){
// Read Battery Voltage
if(0x00 === bytes[i] && 0xFF === bytes[i+1]){
params.battery_voltage = 0.01 * ((bytes[i+2] << 8) | bytes[i+3]);
i = i+3;
// Read Output 1
if(0x01 === bytes[i] && 0x01 === bytes[i+1]){
if(0x00 === bytes[i+2]) {
params.output_1 = "open";
} else if(0xFF === bytes[i+2]) {
params.output_1 = "closed";
i = i+2;
// Read Output 2
if(0x02 === bytes[i] && 0x01 === bytes[i+1]){
params.output_2 = "open";
params.output_2 = "closed";
i = i+2;
// Read Temperature
if(0x03 === bytes[i] && 0x67 === bytes[i+1]){
params.temperature = (bytes[i+2]<<24>>16 | bytes[i+3]) / 10;
i = i+3;
// Read Input 1 State
if(0x05 === bytes[i] && 0x00 === bytes[i+1]){
params.input_1_state = false;
params.input_1_state = true;
i = i+2;
// Read Input 2
if(0x06 === bytes[i] && 0x02 === bytes[i+1]){
// 2 Bytes of data to consume
// Read Input 3
if(0x07 === bytes[i] && 0x02 === bytes[i+1]){
// Read Input 1 Count
if(0x08 === bytes[i] && 0x04 === bytes[i+1]){
return params
I will be updating the decoder as I progress.
Encoder (TBA)
Cheers,
Coach
