How to use an external MQTT broker and add devices through the Chirpstack Dashboard?
in the chirpstack configuration i want to point to an external mqtt broker:
[integration.mqtt]
server = “mqtt://localhost:1883”
Dynamically configuring credentials using tags
username_template = “{{ .Tags.mqtt_username }}”
password_template = “{{ .Tags.mqtt_password }}”
is this the correct configuration? why in the logs of badusername
Do you mean you want to use an external MQTT broker for the backhaul of Chirpstack (i.e the communication between the gateways and Chirpstack), if that is the case you would have to change the MQTT backend section in your regional .toml file, and the integration section in your gateway bridge / mqtt forwarder.
If you are only trying to get the integration going, to forward decrypted MQTT device events to an external broker. Then you just need to change the server= line you referenced there to the IP of the external broker. If you are looking to add credentials to that here is the full list of configuration options for the MQTT integration:
# MQTT integration configuration.
  [integration.mqtt]
    # Event topic template.
    event_topic="application/{{application_id}}/device/{{dev_eui}}/event/{{event}}"
    # Command topic.
    # This is the topic on which the MQTT subscribes for receiving (enqueue) commands.
    command_topic="application/{{application_id}}/device/{{dev_eui}}/command/{{command}}"
    # Use JSON encoding instead of Protobuf (binary).
    json=true
    server="tcp://127.0.0.1:1883/"
    username=""
    password=""
    # Quality of service level
    # 0: at most once
    # 1: at least once
    # 2: exactly once
    qos=0
    # Clean session
    clean_session=false
    # Client ID
    # broker. A client id must be no longer than 23 characters. If left blank,
    # a random id will be generated by ChirpStack.
    client_id=""
    # Keep alive interval.
    # This defines the maximum time that that should pass without communication
    # between the client and server.
    keep_alive_interval="30s"
    ca_cert=""
    tls_cert=""
    # TLS key file (PKCS#8) (optional)
    tls_key=""
Hi Philipp!
I managed to do the tests. Thank you.
To simplify my operation even more. I virtualized my chirpstack and use the Tago platform. And through HTTP integration, I send the information to Tago. I just need to register my gateways, then create the applications and add the Lora devices. In Tago, I only add the devices with the Everynet customization.
The payloads arrive perfectly without any major challenges.
