I have a gateway with udp packet forwarder and chirpstack gateway bridge installed.
I try to use net_ids and join_EUI filters…
Do you have a specific question? The configuration explains the syntax with examples:
Thank you for your reply.
I’m sorry but I accidentally sent the message.
I finally managed to set up filtering on my gateway.
I have installed ChirpStack Gateway Bridge inside a TTN / TTOG (Gemtek / Browan) gateway and update the /app/cfg/global_conf0.json with server : localhost ul_port : 1700 dl_port : 1700. I have also updated the ChirpStack Gateway Bridge configuration file with a link to our Cloud Network Server (ChirpStack). All is working well. I try to go a step further adding a NetID inside Network Configuration file (toml server) and inside Gateway Bridge configuration file (toml gateway) but it’s seems that nothing is filtering, I can see all the uplink frames around our gateway. I’m missing something in the configuration ?
We try to reduce data usage on our 4G backhaul.
Gateway : packet forwarder UDP and chirpsatck gateway bridge inside
global_conf.json :
“keepalive_interval”: 10,
“stat_interval”: 30,
Filtering : by NetID and JoinEUI ok
Now we stop all the devices and remove the antenna (868MHz).
Chirpstack-Gateway-Bridge logs show few frames (keepalive / stat) but we consume 5MB/day.
Consumption inherent to SIM = 300kB/day
keepalive/stat = 300kB/day
Someone have an idea about why we consume near 5MB /day.
Sending a gateway stat payload every 30 seconds is extremely frequent (yes, this is the default for many packet forwarders, but still). Do you need gateway stats that frequently? For cellular backhaul, I usually set it to every 15 minutes, or perhaps hourly. It will depend on the use case, of course.
Edit:
Are you sure about that? Stat payloads from the Semtech packet forwarder are verbose.
KeepAlive/STAT = 300kB/day with KA = 60s & STAT = 60s
KA = 10s / STAT = 30s => ~7MB/day
KA = 60s / STAT = 60s => ~5MB/day
KA = 120s / STAT = 300s => ~5MB/day ???
We are working with our SIM supplier to analyze the traffic and understand the origin the 5MB/day.
So doubling the keep-alive and stats delay results in the same usage? I do not believe your bandwidth reporting is accurate.
I don’t believe too…
I have check the traffic on the network server side with the MQTT broker via a subscribe to the concern gateway and i can see that the traffic is very low and in phase with the global_conf parameters. So the 5MB/day are not related to LoRaWAN traffic…
