HTTP integration Error 400 in log
I installed a HTTP integration with the header:
  • Content-type: application/json
  • Authorization: Basic <>
    URL: https://...es.io:9243/index/_doc/?event=up?
I get an error in the log saying:
time="..." level=error msg="integration/http: publish event error" ctx_id=<> dev_eui=<> error="expected 2XX response, got: 400" event_type=up url="https://<>.es.io:9243/index/_doc/?event=up"
The chirpstack webui does provide a valid let’s encrypt certificate.
When I change the URL to a Postman mock server I receive it successfully.
What could be the reason for this?
Thanks for your support.
Lukas
The error indicates that your endpoint returned a 400 status, but a 2XX status is expected. You should inspect why your endpoint is returning a 400 status.
I have configured these headers and then it works from Postman and curl to ES:
The body is: {“test”:“20230630”}
curl: $ curl --location ‘https://.europe-west1.gcp.cloud.es.io:9243/index/_doc/’
–header ‘Content-type: application/json’
–header ‘Authorization: Basic xxx=’
–data ‘{“test”:“20230630”}’
TTN works:
Chirpstack is sending which
does not work.
What do you think regarding the headers?
BR
Lukas
@brocaar What do you think regarding the headers?
When I add /?event=up to the url and try using postman:
url=“<>es.io:9243/index/_doc/?event=up” then the uplink does not create a document on es.
curl command: curl --location ‘https://<>.es.io:9243/index/?event=up’
–header ‘Authorization: Basic ’
–data ‘{“testkey”:“testvalue”}’
