Hello, I have been using http integration,I wanted to ask : Is there a limitation on the number of the http post (uplinks) that are sent from an application (for example max 3000 in a minute) ? or it is limitless ? and also there should be a time interval between each http post or not ?
Thank you
Hi ,
I think the limitation will be more on the hosting side than on Chirpstack side…
Hi, thanks.then it’s perfect
