I’ve set up a HTTP integration and set the endpoints to a script on my server (http://example.com/testdata.php) but i’m not seeing any calls from the loraserver. Is there something else I should be doing to get it working?
I’m expecting to see the LoRaServer POST to this script when data is received from a remote node. Is that correct?
When you’re using the Debian / Ubuntu packages. They are either in /var/log/lora-app-server or you should be able to see them by executing journalctl -f -n 100 -u lora-app-server (in case of systemd).
It works with Request bin so there must be something going on with the server I am pointing it to. I have no idea what though. A standard browser request works so I guess the integration request should work too?
Hi, is there any way how to setup HTTP integration with elastic?
becasue Chirpstack adds event as query parameter and url looks like: http://app.xxxxxxxxx.com:9200/humid-temp/_doc?event=up, which is invalid exception path for elastic API and I am getting exception from elastic
