in case it might help someone
I’m sending temperature and humidity from node
Cayenne LPP codec
here is the configuration in loraserver application
and payload parser in tago.io
// Add ignorable variables in this array.
const ignore_vars = ['applicationID','adr','applicationName','deviceName','devEUI','gatewayID','name',
'rssi','loRaSNR','location','frequency','fPort','fCnt','txInfo','rxInfo','object'];
function toTagoFormat(object_item, serie, prefix = '') {
const result = [];
for (const key in object_item) {
if (ignore_vars.includes(key)) continue;
if (typeof object_item[key] == 'object') {
result.push({
variable: object_item[key].variable || `${prefix}${key}`,
value: object_item[key].value,
serie: object_item[key].serie || serie,
metadata: object_item[key].metadata,
unit: object_item[key].unit,
} else {
result.push({
variable: `${prefix}${key}`,
value: object_item[key],
serie,
return result;
if (!payload[0].variable) {
//Get a unique serie for the incoming data.
const serie = payload[0].serie || new Date().getTime();
payload = toTagoFormat(payload[0], serie);
const rawObject = payload.find(item => item.variable === "data");
var rawData = rawObject.value;//.toString('utf8');
const buffer = Buffer.from(rawData, 'base64');
payload.push({"variable" : "buffDisplay" , "value" : buffer.toString('hex')})
payload.push({"variable" : "Temperature" , "value" : buffer.slice(2,4).readInt16BE() / 10 , "unit" : '°C' });
payload.push({"variable" : "Humidity" , "value" : buffer.slice(6,7).readUInt8() / 2 , "unit" : '%' });
Regards
Mike
