I took the python script provided in the following link to get uplink data from application sever with POST request.
But I think we need a protocol buffer file as per this line
“from chirpstack_api.as_pb import integration”
but I am not sure where to find the protocol buffer file as the page above does not tell where it can be located.
When I tun the script I was getting this error (running script from python 3 docker container )
python_chirpstack_adapter_1 | Traceback (most recent call last):
python_chirpstack_adapter_1 | File "/usr/src/app/./main.py", line 4, in <module>
python_chirpstack_adapter_1 | from chirpstack_api.as_pb import integration
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/chirpstack_api/as_pb/__init__.py", line 1, in <module>
python_chirpstack_adapter_1 | from .as_pb_pb2_grpc import *
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/chirpstack_api/as_pb/as_pb_pb2_grpc.py", line 5, in <module>
python_chirpstack_adapter_1 | from chirpstack_api.as_pb import as_pb_pb2 as chirpstack__api_dot_as__pb_dot_as__pb__pb2
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/chirpstack_api/as_pb/as_pb_pb2.py", line 17, in <module>
python_chirpstack_adapter_1 | from chirpstack_api.common import common_pb2 as chirpstack__api_dot_common_dot_common__pb2
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/chirpstack_api/common/__init__.py", line 1, in <module>
python_chirpstack_adapter_1 | from .common_pb2 import *
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/chirpstack_api/common/common_pb2.py", line 33, in <module>
python_chirpstack_adapter_1 | _descriptor.EnumValueDescriptor(
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/google/protobuf/descriptor.py", line 755, in __new__
python_chirpstack_adapter_1 | _message.Message._CheckCalledFromGeneratedFile()
python_chirpstack_adapter_1 | TypeError: Descriptors cannot not be created directly.
python_chirpstack_adapter_1 | If this call came from a _pb2.py file, your generated code is out of date and must be regenerated with protoc >= 3.19.0.
python_chirpstack_adapter_1 | If you cannot immediately regenerate your protos, some other possible workarounds are:
python_chirpstack_adapter_1 | 1. Downgrade the protobuf package to 3.20.x or lower.
python_chirpstack_adapter_1 | 2. Set PROTOCOL_BUFFERS_PYTHON_IMPLEMENTATION=python (but this will use pure-Python parsing and will be much slower).
python_chirpstack_adapter_1 | More information: https://developers.google.com/protocol-buffers/docs/news/2022-05-06#python-updates
python_scripts_python_chirpstack_adapter_1 exited with code 1
I resolved the above error by adding environment variable “PROTOCOL_BUFFERS_PYTHON_IMPLEMENTATION” at start of the file like this
import os
os.environ["PROTOCOL_BUFFERS_PYTHON_IMPLEMENTATION"]='python'
Now when I send an uplink I am getting this error
python_chirpstack_adapter_1 | 103.92.102.92 - - [17/Nov/2022 13:30:32] "POST /?event=up HTTP/1.1" 200 -
python_chirpstack_adapter_1 | ----------------------------------------
python_chirpstack_adapter_1 | Exception occurred during processing of request from ('103.92.102.92', 50898)
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/google/protobuf/json_format.py", line 544, in _ConvertFieldValuePair
python_chirpstack_adapter_1 | raise ParseError(
python_chirpstack_adapter_1 | google.protobuf.json_format.ParseError: Message type "integration.UplinkEvent" has no field named "deduplicationId" at "UplinkEvent".
python_chirpstack_adapter_1 | Available Fields(except extensions): "['applicationID', 'applicationName', 'deviceName', 'devEUI', 'rxInfo', 'txInfo', 'adr', 'dr', 'fCnt', 'fPort', 'data', 'objectJSON', 'tags', 'confirmedUplink', 'devAddr', 'publishedAt', 'deviceProfileID', 'deviceProfileName']"
python_chirpstack_adapter_1 | During handling of the above exception, another exception occurred:
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/socketserver.py", line 317, in _handle_request_noblock
python_chirpstack_adapter_1 | self.process_request(request, client_address)
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/socketserver.py", line 348, in process_request
python_chirpstack_adapter_1 | self.finish_request(request, client_address)
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/socketserver.py", line 361, in finish_request
python_chirpstack_adapter_1 | self.RequestHandlerClass(request, client_address, self)
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/socketserver.py", line 755, in __init__
python_chirpstack_adapter_1 | self.handle()
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/http/server.py", line 431, in handle
python_chirpstack_adapter_1 | self.handle_one_request()
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/http/server.py", line 419, in handle_one_request
python_chirpstack_adapter_1 | method()
python_chirpstack_adapter_1 | File "/usr/src/app/./main.py", line 24, in do_POST
python_chirpstack_adapter_1 | self.up(body)
python_chirpstack_adapter_1 | File "/usr/src/app/./main.py", line 33, in up
python_chirpstack_adapter_1 | up = self.unmarshal(body, integration.UplinkEvent())
python_chirpstack_adapter_1 | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
python_chirpstack_adapter_1 | File "/usr/src/app/./main.py", line 42, in unmarshal
python_chirpstack_adapter_1 | return Parse(body, pl)
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/google/protobuf/json_format.py", line 436, in Parse
python_chirpstack_adapter_1 | return ParseDict(js, message, ignore_unknown_fields, descriptor_pool,
python_chirpstack_adapter_1 | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/google/protobuf/json_format.py", line 461, in ParseDict
python_chirpstack_adapter_1 | parser.ConvertMessage(js_dict, message, '')
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/google/protobuf/json_format.py", line 502, in ConvertMessage
python_chirpstack_adapter_1 | self._ConvertFieldValuePair(value, message, path)
python_chirpstack_adapter_1 | File "/usr/local/lib/python3.11/site-packages/google/protobuf/json_format.py", line 629, in _ConvertFieldValuePair
python_chirpstack_adapter_1 | raise ParseError(str(e))
I am using JSON marshaler and I have set “json = True” in the scritpt
I think the protocol buffers are not updated to handle new variables (I am not an expert on protocol buffers and just a beginner).
I have mqtt integration and captured the uplink payload which is appearing on topic
application/7c7746bb-bc82-41b7-9a32-211fdcb72651/device/506f98000000ac63/event/up
"deduplicationId": "2272a61d-41b3-404a-a081-49295df6463f",
"time": "2022-11-17T13:30:56.476834105+00:00",
"deviceInfo": {
"tenantId": "52f14cd4-c6f1-4fbd-8f87-4025e1d49242",
"tenantName": "ChirpStack",
"applicationId": "7c7746bb-bc82-41b7-9a32-211fdcb72651",
"applicationName": "locathost",
"deviceProfileId": "5fd57ed5-cb76-4e00-ace7-3bdcb223946c",
"deviceProfileName": "device_profile",
"deviceName": "Node_506f98000000ac63",
"devEui": "506f98000000ac63"
"devAddr": "0000ac63",
"adr": true,
"fCnt": 4,
"fPort": 7,
"confirmed": true,
"data": "MA==",
"rxInfo": [
"gatewayId": "dabbccffff2a79cb",
"uplinkId": 51976,
"rssi": -43,
"snr": 8.0,
"channel": 3,
"location": {},
"context": "qRlwdw==",
"metadata": {
"region_name": "in865",
"region_common_name": "IN865"
"txInfo": {
"frequency": 865402500,
"modulation": {
"lora": {
"bandwidth": 125000,
"spreadingFactor": 12,
"codeRate": "CR_4_5"
I have setup the Chirpstack version 4 sever using docker today which I think is the latest build.
I am running a simulator for uplink but the data sent is an actual sample of real data transmitted by a device.
I have the following questions:
a. How do I resolve the above error ?
b. Where do I get protocol buffer file so I dont have to use environment variable
c. The python script does not show how to perform a downlink. Can I get an sample code to do this? (with and without MQTT integration )
d. I would like to implement the server in NodeJS instead of Python. Is there any sample code to do this ?
Thanks
Regards,
Harsha
