HTTPS integration x509 error
Hi!, I’m a quite newbie in LoRaWAN. First of all, thank you for this awesome work! and I apologize for my English, it’s not very good :anguished:
I’ve tried to use the http integration to send device uplink data to my server. But our serve uses https, so the configured URL is something like https://…
When POST is done I’ve obtained the following error: appserver_1 | time=“2020-05-21T06:49:10Z” level=error msg=“integration/multi: integration error” ctx_id=19ac6cfa-d5fd-4013-96c9-85b3daf5be12 error=“send error: http request error: Post https://…my server…: x509: certificate signed by unknown authority” integration="*http.Integration"
How can I solve this issue?
I’ve also read https://github.com/brocaar/chirpstack-certificates and I’ve generated them successfully, but I don’t know what .toml configuration file has to be used to set these certificates (which one must be used, what section has to be used…)
I’ve also test to use a bin from https://postb.in, and then no error is returned and I’m able to see in the bin the POST information… I don’t understand…
I’m sorry if this issue is solved somewhere in the forum and perhaps it’s a too basic issue.
Can anyone help me?
Thank you in advance for your help.
Any solution, please?
Thank you
Use a certificate that is signed by a trusted certificate :slight_smile:
Hello, brocaar
Thank you for your reply.
I think this certificate has to be set in the chirpstack-application-server.toml configuration file, is it that correct? and what section/item has to be used?
I’m sorry because it’s possible my questions are too basic.
Thank you for your help.
This is not possible. When it is a TLS certificate for a public domainname, then you could use for example https://letsencrypt.org/. An other way is to add your self-signed certificate to the trusted certificates of your OS.
This could be helpful: curl - Adding a self-signed certificate to the "trusted list" - Unix & Linux Stack Exchange.
