Hi everyone.
First of all, I’m a newbie in this field.
I have a problem setting the ‘chirpstack-application-server’ certification part.
I am working on Windows Server 2008 R2 x64bit OS system.
I generated an SSL certificate with @brocaar script GitHub - brocaar/chirpstack-certificates: Scripts to generate certificates for the ChirpStack components. on Raspberry Pi 3.
And then I copied the full cert to my Windows server Folder.
I set the correct part of “chirpstack-application-server.toml”.
ca_cert="C:\path of cert"
tls_cert="C:\path of cert"
# TLS key file (optional)
tls_key="C:\path of cert"
When testing the HTTPS connection.
https://IP:8080/#/login
I get this error message on my browser:
SSL_ERROR_RX_RECORD_TOO_LONG
Can anyone help solve this problem?
