I can't send frame to my sensor
during my internship i want to send some data to my lorawan sensor using chirpstack “queue” functionnality.
I use the REST APi to send my hexa data, for example : “090def8ff400”. The value appears correctly in the web interface queue. When the frame is sent, the value in “frm_payload” is not the same.
Could you tell me what operations were carried out on the data that would explain these changes?
The frm_payload is encrypted as per LoRaWAN standards.
The downlink data will be decoded in your node.
But i don’t click on “is encrypted yes”
or it’s another encryption?
The “is encrypted” box means you’ve already encrypted it and it should be sent as-is. You probably don’t want that. The LNS will encrypt and send it for you.
thank you for your answer!
