Hi Community, I’m new and already issues
I have a full image 4.3.2 on rapsby pi 3 and a shield and a IC880A, I used to use an old version of Chirpstack without web and it was working, I think because I could change the PIN reset, now on this version, I cannot.
The exact shield is this GitHub - ch2i/iC880A-Raspberry-PI: Raspberry PI iC880A and LinkLab Lora Gateway Shield
And from system log, I get this cntinuously every 5 secs and cannot see the gateway on chirpstack :
Sat Feb 17 13:12:03 2024 user.info chirpstack-concentratord-sx1301[24651]: Starting the concentrator
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring reset pin, dev: /dev/gpiochip0, pin: 5
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Starting Concentratord SX1301 (version: 4.3.5, docs: Introduction - ChirpStack open-source LoRaWAN® Network Server documentation)
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Triggering sx1302 reset
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Setting spi device path, spidev_path: /dev/spidev0.0
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Setting board configuration, lorawan_public: true, clock_source: 1
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Setting up concentrator radios
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Setting up concentrator channels
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Sat Feb 17 13:12:08 2024 user.info chirpstack-concentratord-sx1301[24657]: Starting the concentrator
Sat Feb 17 13:12:13 2024 user.info chirpstack-concentratord-sx1301[24662]: Configuring reset pin, dev: /dev/gpiochip0, pin: 5
Sat Feb 17 13:12:13 2024 user.info chirpstack-concentratord-sx1301[24662]: Starting Concentratord SX1301 (version: 4.3.5, docs:)
Sat Feb 17 13:12:13 2024 user.info chirpstack-concentratord-sx1301[24662]: Triggering sx1302 reset
I tried to get rid of the shield and do with jumper from the rapsberry to the IC880A but it does not even start.
Did someone face this ?
Thanks !!
Joseph
