I am using IMST - iC880A gateway. how to configure the chirpstack-gateway-os-full in raspberry pi 3 b+ board and how to setup the Lora concentrator shield. while selecting Lora concentrator shield. i am getting pin configuration messages i don’t no how set pin configuration in Lora concentrator shield. I want setup every thing in raspberry pi whatever you are given features. can you please guide us.
https://youtu.be/np4rIQ_teR4
The first link is about configuring the gateway (plz discard the TTN portion unless you want to go for it), whereas the second one is about installing the loraserver on gateway, which is what you’re looking for. However the hardware used in the second resource is different, so the procedure might differ. Also you might have to refer to some of the other videos in the video series of the latter author, for better clarity on certain aspects (especially config files in video numbers 28 and 28.1 of the series https://www.youtube.com/playlist?list=PLmL13yqb6OxdeOi97EvI8QeO8o-PqeQ0g). Hope this helps.
Even I’m looking for some help on gateway OS image files appropriate for imst. The image folder has many files, and I’m not able decide which one should I go for.
The thing is, with the iMST iC880A shield there are many pin options possible, this might depend on the instructions you are following or on the kit you are using.
This information is 2 years old when I first worked with the gateway. But maybe it helps with the setup. A tested tutorial how to use Chiprpstack OS on the IMST Lite GW would be very nice. I have not tested it but expect to run into Pin Configuration issues.
