I have a recent (2 weeks order) IMST Lite Gateway unit and I’m having issues with ChirpStackOS using the “raspberry 1” image (the gateway has an old raspberry in it…)
Specifically what I see is that to get the concentrator running every time I boot the unit I have to run “setup gateway-config” and always select i880a, EU868, gpio 24.
If I don’t do this step … the monit status is telling me that the concentrator is missing.
So I’ve found this thread which has the same problem:
but things are a bit different:
my gpio is 24 (I did check manually with a reset script and I see the red LED on the concentrator to blink only if I select 24)
I do not see any reset script under /etc/init.d using the lastest ChirpstackOS image for raspberry-1
any hint?
how can I automatically run the proper configuration at boot so that the gateway works also on power cycle?
thanks
