Gateway OS base image does not contains IN865 for RAK2245,
is there any other method through which i can configure it?
Hi Akash_Rao
Did you get the any idea how to configure IN865 for RAK2245 in Gateway OS base image?
Please create an issue here to request support for IN865: https://github.com/brocaar/chirpstack-gateway-os
hello
i am using chripstack full os with raspberry pi and ic880a i want to use it with IN865 i have done changes in chirpstack concentratord config files i have attached my changes and my network server also up and running with in865 but concentratrod is failing to initialise?is changing config files and restarting the concentratord is enough or do i have to do any other thing?can you check my configuration files and tell what i am doing wrong
thanks and regards
manikandan v
