I have installed ChirpStack v4 with docker and using a gateway with bridge v3, I get messages from end nodes with protobuf formatting through MQTT.
Now, I’m looking to integrate InfluxDB v2.7.0. The device profiles codec return a dummy value for test purposes, I see it on the Events windows and the decoded uplink reaches mosquitto.
The influxDB v2 integration is done in the application with bucket and token configured, the docker bridge IP is used for the API.
Where should I look to understand why the payload is not written on influxDB?
Regards
