InfluxDB Integration with multiple gateways to get metadata
I wonder how to InfluxDB integration proceed to store multiple gateways uplink meta-data that shall be different.
I suceed to get gateway uplink meta-data when device is received by only one gateway.
But when device is received by 2 (or more) gateways, it seems that only one gateway uplink meta-data is stored ?
Is that true ?
Thanks,
Nop
I have double check code in
internal/integration/influxdb/influxdb.go
line 190 :
if len(pl.RXInfo) != 0 {
	var rssi int
	for i, rxInfo := range pl.RXInfo {
		if i == 0 || rxInfo.RSSI > rssi {
			rssi = rxInfo.RSSI
	var snr float64
		if i == 0 || rxInfo.LoRaSNR > snr {
			snr = rxInfo.LoRaSNR
	measurements[0].Values["rssi"] = rssi
	measurements[0].Values["snr"] = snr
Only best RSSI and SNR are sent to InfluxdB, not all the gateways information.
It means that in a multiple gateway conditions, best SNR and best RSSI are not necessary provided by the same gateway.
May it be possible to store all gateways RSSI, SNR information from uplink metadata in influxdB?
Thanks,
Nop
There is no way to store lists / arrays / slices in InfluxDB I believe.
Would pl.RXInfo be definitive of the number of gateways that received an uplink?
The number of gateways that received the packet could be a very useful measurement.
:slight_smile:
