Hi all -
I recently enabled Postgres integration and am receiving the following error in syslog:
lora-app-server[9962]: time=“2019-09-04T21:42:26+01:00” level=error msg=“integration/multi: integration *postgresql.Integration error” error=“insert error: pq: unsupported Unicode escape sequence”
Any ideas how to troubleshoot this or what can be causing this? I’m just trying to get get any uplink error messages into postgres.
Thanks!
Mk…
bconway
#2
Do any of your devices have emoji in their names?
11113
#3
Hello! I have the same problem! Did you solve it?
brocaar
#4
A good first step would be to validate the character-set configuration of your database: https://www.postgresql.org/docs/current/multibyte.html.
Then you might want to look into your PostgreSQL logs to find out what exact query is failing.
