Hello
I was using TTN, and now I wanna make a transition to ChirpStack. I’ve installed all components of the Chirpstack on a Ubuntu desktop by following these two resources (https://www.youtube.com/watch?v=FnTP7t47DlI&list=PL9FegcZTeB9LRLnXtN6OMkVSZYgHdlmOr, and https://www.youtube.com/watch?v=np4rIQ_teR4&t=223s). I had a great difficulty in modifying the chirpstack-gateway-bridge.toml, global_config.json and local_config.json files, especially because I was already using the latter two files associated with TTN.
After installing all the components (GWB, NS and AS), when I had run the status of network-server and that of application-server, no errors were seen. But after modifying gwb.toml and config files, I’m seeing the following errors:
samdani@samdani-Veriton-M200-H61:~$ systemctl status chirpstack-application-server
● chirpstack-application-server.service - ChirpStack Application Server
Loaded: loaded (/lib/systemd/system/chirpstack-application-server.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2019-11-30 08:19:37 IST; 4h 40min ago
Docs: https://www.chirpstack.io/
Main PID: 13712 (chirpstack-appl)
Tasks: 14 (limit: 4915)
Memory: 25.0M
CGroup: /system.slice/chirpstack-application-server.service
└─13712 /usr/bin/chirpstack-application-server
Nov 30 12:42:37 samdani-Veriton-M200-H61 chirpstack-application-server[13712]: time=“2019-11-30T12:42:37+05:30” level=info msg=“finished unary call with code OK” ctx_id
Nov 30 12:42:45 samdani-Veriton-M200-H61 chirpstack-application-server[13712]: time=“2019-11-30T12:42:45+05:30” level=info msg=“finished unary call with code OK” ctx_id
Nov 30 12:43:08 samdani-Veriton-M200-H61 chirpstack-application-server[13712]: time=“2019-11-30T12:43:08+05:30” level=info msg=“finished client unary call” ctx_id=4eb45
Nov 30 12:43:08 samdani-Veriton-M200-H61 chirpstack-application-server[13712]: time=“2019-11-30T12:43:08+05:30” level=info msg=“finished unary call with code OK” ctx_id
Nov 30 12:43:27 samdani-Veriton-M200-H61 chirpstack-application-server[13712]: time=“2019-11-30T12:43:27+05:30” level=info msg=“finished unary call with code OK” ctx_id
Nov 30 12:43:28 samdani-Veriton-M200-H61 chirpstack-application-server[13712]: time=“2019-11-30T12:43:28+05:30” level=info msg=“finished client unary call” ctx_id=fba6b
Nov 30 12:43:28 samdani-Veriton-M200-H61 chirpstack-application-server[13712]: time=“2019-11-30T12:43:28+05:30” level=info msg=“finished unary call with code OK” ctx_id
Nov 30 12:43:28 samdani-Veriton-M200-H61 chirpstack-application-server[13712]: time=“2019-11-30T12:43:28+05:30” level=info msg=“finished client unary call” ctx_id=7c788
samdani@samdani-Veriton-M200-H61:~$ systemctl status chirpstack-network-server
● chirpstack-network-server.service - ChirpStack Network Server
Loaded: loaded (/lib/systemd/system/chirpstack-network-server.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2019-11-30 08:31:13 IST; 4h 29min ago
Main PID: 14247 (chirpstack-netw)
Tasks: 13 (limit: 4915)
Memory: 7.3M
CGroup: /system.slice/chirpstack-network-server.service
└─14247 /usr/bin/chirpstack-network-server
Nov 30 12:42:21 samdani-Veriton-M200-H61 chirpstack-network-server[14247]: time=“2019-11-30T12:42:21+05:30” level=info msg=“finished unary call with code OK” ctx_id=1bf
Nov 30 12:42:21 samdani-Veriton-M200-H61 chirpstack-network-server[14247]: time=“2019-11-30T12:42:21+05:30” level=info msg=“finished unary call with code OK” ctx_id=f3b
Nov 30 12:42:21 samdani-Veriton-M200-H61 chirpstack-network-server[14247]: time=“2019-11-30T12:42:21+05:30” level=info msg=“finished unary call with code OK” ctx_id=e47
Nov 30 12:42:33 samdani-Veriton-M200-H61 chirpstack-network-server[14247]: time=“2019-11-30T12:42:33+05:30” level=info msg=“finished unary call with code OK” ctx_id=9f2
Nov 30 12:42:36 samdani-Veriton-M200-H61 chirpstack-network-server[14247]: time=“2019-11-30T12:42:36+05:30” level=info msg=“finished unary call with code OK” ctx_id=2da
Nov 30 12:42:36 samdani-Veriton-M200-H61 chirpstack-network-server[14247]: time=“2019-11-30T12:42:36+05:30” level=info msg=“finished unary call with code OK” ctx_id=cfd
Nov 30 12:42:37 samdani-Veriton-M200-H61 chirpstack-network-server[14247]: time=“2019-11-30T12:42:37+05:30” level=info msg=“finished unary call with code OK” ctx_id=c67
Nov 30 12:43:08 samdani-Veriton-M200-H61 chirpstack-network-server[14247]: time=“2019-11-30T12:43:08+05:30” level=info msg=“finished unary call with code OK” ctx_id=fad
Nov 30 12:43:28 samdani-Veriton-M200-H61 chirpstack-network-server[14247]: time=“2019-11-30T12:43:28+05:30” level=info msg=“finished unary call with code OK” ctx_id=1f8
Nov 30 12:43:28 samdani-Veriton-M200-H61 chirpstack-network-server[14247]: time=“2019-11-30T12:43:28+05:30” level=info msg=“finished unary call with code OK” ctx_id=5f2
I’m afraid its not going to be a smooth transition. Anybody tried migrating successfully from TTN to ChirpStack?
