I am trying sent to AMQ.TOPIC broker of RabbitMQ, registered device’s message on chirpstack AS.
i found this section in confiuration file of Chirpstack AS.
# AMQP / RabbitMQ.
[application_server.integration.amqp]
# Server URL.
# See for a specification of all the possible options:
# https://www.rabbitmq.com/uri-spec.html
# url="amqp://guest:guest@localhost:5672"
url="mqtt://mqtt-user:mqtt-user@localhost:5672"
# Event routing key template.
# This is the event routing-key template used when publishing device
# events. Messages will be published to the "amq.topic" exchange.
# event_routing_key_template="application.{{ .ApplicationID }}.device.{{ .DevEUI }}.event.{{ .EventType }}"
event_routing_key_template="application.{{ .1 }}.device.{{ .1000000000001001 }}.event.{{ .up }}"
but amq.topic cant listen my configuration. Someone did this solution ?
