I have integrated sX1302 on raspberry pie and flash chirpstack on the raspberry pie. I am using that device as a gateway as well as also as a network or application server and secondly I have sx 1262 new generation LoRa node for raspberry pie which I have mounted on . I have developed a code in which that code is transmitting the data frames, but that data frame is coming under LoRa frames of gateway. Even my gateway is online and the payload which is seen at the packet is in encrypted form. I have also checked the keys which are same. The Python which I have the same key as that of the keys in the Application server, what would be the reason please help?
Uploading: image.jpg…
Processing: image.jpg…
