is it possible to integrate loriot with chirpstack such that it is able to send downlink data to loriot?
Check out Chirpstack’s integrations. If Loriot doesn’t support one of these then no. Also I assume you mean to send uplink not downlink data to Loriot.
actually i was thinking if i use chirpstack server as network server and loriot as application server not sure if that works? I also meant the downlink data
I don’t know how much support Loriot has for that but you can look into this: End-to-end encryption - ChirpStack open-source LoRaWAN® Network Server documentation
