- I connected the ChirpStack server to my server using “HTTP Integrations.”
- When everything works normally, the downlink response arrives within 0-1 seconds after sending the uplink data.
- However, in abnormal cases, the downlink response either does not arrive or takes more than 90 seconds.
- To identify the issue, I tried to check and modify the settings in the
chirpstack.tomlfile, but there are no HTTP-related settings mentioned, so I am unsure what to adjust. - For example, I wanted to configure something like the
retry interval.
Could you please advise on which settings I should modify to resolve this issue? Any guidance would be greatly appreciated.
[normal]
[abnormal]
