In the integration.proto file I see that the UplinkEvent message contains the field ‘confirmed_uplink’ however when I dump the kafka messages I get from uplinks that field is never present. My devices currently send confirmed uplinks every six messages.
I know those messages are sent, and marked as confirmed, as use the Redis stream, lora:ns:device:stream:frame, to debug.
Is this what I would expect of does it indicate I’ve done something wrong. If it is what I should expect is there a later version of the Application server where the ‘confirmed_uplink’ is present in the kafka message?
I’m running Chirpstack in Docker, I think the version is 3.17.2, but unsure as the “chirpstack-application-server version” command run within docker returns a blank line.
Thanks in advance.
