I am running Chirpstack and I have encountered an issue that I’m hoping to get some help with. I searched the forums, but didn’t find any issues substantially similar to mine.
I can provide any logs, configuration, or additional information required upon request.
When I boot up my LoRa device, my sensor will not successfully communicate correctly for a period of time before the sensor internally resets and requests a new Join. This is repeatable and happens every time.
Here is the sequence if the sensor and LoRa device are turned on at the same time:
-JoinRequest
-JoinAccept
-ConfirmedUp
-UnconfirmedDown
-ConfirmedUp
-ConfirmedUp
-ConfirmedUp
-ConfirmedUp
-ConfirmedUp
-…etc until the sensor does an internal reset
-JoinRequest
-JoinAccept
-ConfirmedUp
-UnconfirmedDown
-ConfirmedUp
-UnconfirmedDown
-…and so on, it works as expected now
If the LoRa device is restarted but the sensor is not, it looks like this:
-ConfirmedUp
-ConfirmedUp
-ConfirmedUp
-ConfirmedUp
-ConfirmedUp
-JoinRequest
-JoinAccept
-ConfirmedUp
-UnconfirmedDown
-ConfirmedUp
-UnconfirmedDown
I have looked at the transmissions as best I can, but I don’t understand what is going on or why the message are being “ignored” by Chirpstack until the device does a Join the second time.
There is a lot of data, so I will link it:
Cold Start Test
Device Frames: Cold_Start_Device_Frames - Pastebin.com
Gateway Frames: Cold_Start_Gateway_Frames - Pastebin.com
Test Narrative: Cold_Start_Test_Narrative - Pastebin.com
Screenshots (provided for time stamps on transmissions): https://imgur.com/a/ceOvM6s
Reboot Test
Device Frames: Reboot_Device_Frames - Pastebin.com
Device Data: Reboot_Device_Data - Pastebin.com
Gateway Frames: Reboot_Gateway_Frames - Pastebin.com
Test Narrative: Reboot_Test_Narrative - Pastebin.com
Screenshots (provided for time stamps on transmissions): https://imgur.com/a/ILJz5zH
Please let me know if there’s any other data you need to help troubleshoot this and I’ll provide it.
Thank you very much!
