Hi, I set up lora and lora-app-server in windows. Both services run without errors on the same PC. In the LoRa server app I try to enter the a network server (no entries yet).
Everytime I get the Error rpc error: code = Unknown desc = pq: Relation »routing_profile« existiert nicht (code: 2)
It doesn’t matter if I enter 127.0.0.1:8000, localhost:8000, DNS or IP of the computer.
Log entries:
LORA Server
INFO[0000] starting LoRa Server band="EU_863_870" docs="https://docs.loraserver.io/" net_id=010203 version=0.23.1
INFO[0000] setup redis connection pool url="redis://localhost:6379"
INFO[0000] connecting to postgresql
INFO[0000] backend/gateway: connecting to mqtt broker server="ssl://workstation:8884"
INFO[0000] setup application-server client pool ca_cert= tls_cert= tls_key=
INFO[0000] configuring join-server client ca_cert= server="http://localhost:8003" tls_cert= tls_key=
INFO[0000] backend/gateway: connected to mqtt server
INFO[0000] backend/gateway: subscribing to rx topic topic="gateway/+/rx"
INFO[0000] no network-controller configured
INFO[0000] starting api server bind="0.0.0.0:8000" ca-cert= tls-cert= tls-key=
INFO[0000] starting gateway api server bind="0.0.0.0:8002" ca-cert= tls-cert= tls-key=
INFO[0000] starting downlink device-queue scheduler
INFO[0000] backend/gateway: subscribing to stats topic topic="gateway/+/stats"
ERRO[0000] class-c scheduler error error="get deveuis with class-c device-queue items error: select error: pq: Relation »device« existiert nicht"
LoRa App Server
INFO[0000] starting LoRa App Server docs="https://docs.loraserver.io/" version=0.16.0
INFO[0000] handler/mqtt: connecting to mqtt broker server="ssl://workstation:8884"
INFO[0000] applying database migrations
INFO[0000] handler/mqtt: connected to mqtt broker
INFO[0000] handler/mqtt: subscribling to tx topic topic="application/+/node/+/tx"
INFO[0000] migrations applied count=0
INFO[0000] starting application-server api bind="0.0.0.0:8001" ca-cert= tls-cert= tls-key=
INFO[0000] starting join-server api bind="0.0.0.0:8003" ca_cert= tls_cert= tls_key=
INFO[0000] starting client api server bind="0.0.0.0:8080" tls-cert="c:\lora\server.crt" tls-key="c:\lora\server.key"
INFO[0000] registering rest api handler and documentation endpoint path="/api"
ERRO[0123] network-server create routing-profile api error error="rpc error: code = Unknown desc = pq: Relation »routing_profile« existiert nicht"
The services are startes with following options:
loraserver
--net-id 010203
--band EU_863_870
--gw-server-jwt-secret Vn0DfnL3QyUHUNUeETjPBvKPJ3GOdnxtsRDakIPnXdY=
--postgres-dsn postgres://loraserver_ns:loraserver_ns@localhost/loraserver_ns?sslmode=disable
--gw-mqtt-server ssl://workstation:8884
--gw-mqtt-ca-cert %pfadLora%\ca.crt
--bind 0.0.0.0:8000
--gw-server-bind 0.0.0.0:8002
--js-server http://localhost:8003
--log-node-frames true
--db-automigrate
--gw-create-on-stats
--gw-stats-aggregation-intervals "minute,hour,day"
--log-level 1
--version
lora-app-server
--postgres-dsn postgres://loraserver:loraserver@localhost/loraserver?sslmode=disable
--mqtt-server ssl://workstation:8884
--mqtt-ca-cert %pfadLora%\ca.crt
--jwt-secret VX0DfnL3QyUHUNUeETjPBvKPJ3GOdnxtsRDakIPnXdY=
--db-automigrate
--http-tls-cert %pfadLora%\server.crt
--http-tls-key %pfadLora%\server.key
--as-public-server localhost:8001
--as-public-id 6d5db27e-4ce2-4b2b-b5d7-91f069397978
--bind 0.0.0.0:8001
--http-bind 0.0.0.0:8080
--js-bind 0.0.0.0:8003
Has someone an idea what the problem could be? Thanks for help!
